Sad... Mad... In Need Of Help
aright thanks guys..
i'll pick up some stainless bolts
what do you think about the rusting screw holes? should i re tap them? i think i will then spray them with rust-protective spray
battery charging
If the "modern day" car is running, even at idle but with no other electrical loads, it will fully charge ANY battery appropriate to the car, dead or not. Once the car is running the alternator provides its own field excitation.
And don't I remember that car batteries can be charged to a HIGHer level in colder weather?
A dead Battery will not except the charge that the car provides.
If the battery has any life left in it you can try it with an external charger and try to charge it with a low charge.
Sasha, Sorry to hear about your bad luck with the battery but this isn't the first time you've had "issues" with your electrical system, right?? I thought that was the reason you got the yellow top in the first place. I would get it checked out. I know you've been doing very well with the DIY projects but electrical problems can be tricky. If I remember correctly all the troubles started when you took your "system" out?? I would have someone check there first.
Good luck.
Good luck.
no i've been having problems ever since we got the car... the system made it worse... ever since the subs came out and i put in the yellow top its been fine... i think i hope it was the door
Selective electrons
Richie,
Can you please tell me how a battery manages to discriminate between electrons of one "color" vs another?
Under what circumstance have you encountereed a battery, dead, partially dead, or otherwise that knew from where its charging electrons were coming?
I can readily see where a defective voltage regulator might damage a battery by over-charging it but I fail to see how a properly functioning automotive electrical system could fail to charge a battery.
But I'm willing to learn.
Re: Selective electrons
Search Function Inc.
Ive been having similar problem on my car lately. I think that is just my fault. I will have to go through everything I have ever touched to fix that. I suggest you do the same thing.
P.S. Yellow Top is really hard to kill fast.
Sasha:
Any current draw by a power source will drain an automotive battery within a certain period of time if the battery is not replenished. However, nothing should be wrong with the battery itself.
Frankly, you don't even have to remove the battery to charge it. Just get a jump start and go for a LONG drive (you have a great excuse!)
Just make sure all lights are off for the next few days and start the car after 12 hours or so...
Should be fine... GOOD LUCK!!
Embarrassing
But...
Just this very morning when I went out to start up our 94 AWD Aerostar the doors would not unlock with the remote. so opened using the key and immediately noticed that none of the interior lights came on.
My daughter had left the rotary switch on the headlamp switch on all night. She said she saw that the lights were still on when she locked it up but "knew" they would extinguish automatically once the doors were locked.
But not if they have been left on manually....
I can't say if the battery was completely dead but about twenty minutes on a charger, with the charger still connected on "boost", and the Aerostar started. I let it set and run for about another twenty minutes to further charge the battery and for the rest of the day everything was fine.
The only completely dead battery is one where the residue from the lead plates has piled up in the bottom and is shorting out the plates.
Give me a good automotive lead/acid battery to begin with and we'll discharge it as completely, as DEAD, as you designate and I'll recharge it in any operating, running, automotive system.
