Does anyone know how to remove the A pillar cover from our cars? I want to take it off, but don't want to break anything. I want to remove it so I could fix the damn annoying rattling. I've tried searching, but didn't find anything on how to take it off. Thanks in advance
Here ya go. Look at where the arrows are pointing. Do not pull down. Pull away from the pillars. Obviously pull the top part of the a-pillars first. After the two clips are pulled out from the pillar, you should be able to pull the panels out but pulling it towards you. Easier done than said
NOTE: Make sure you pull down that black strip of seal that's right next to the pillar. You can pull it out with your fingers. Makes things easier. Becareful not to get thermo-grease on you. It's somewhat hard to wash off.
question. how about 01+ gs with curtain airbag, still the same? just curious if the setup is any different
The little button toward the top pops off and has a 10mm behind it. Then you push down a little and pull out to get the bottom. It has a post on it that slides in a groove.
Which car are you doing? 01+ wair bag is totally different than 98-2000 GS
that's exactly my question. 98-00 has no air bag so the a pillar just pops off. but with 01+ curtain airbag, i am not sure if the apillar just pops off like that? that would be dangers when the airbag deploys
