Replacement of stock fog lights?
I have a 200 GS300 without Xenon lights. I have already replaced the regular lights and high-beam with aftermarket PIAA Xtreme White, and I want to replace the fogs now with the same 9006 bulbs. Is it pretty simple or are there any tricks I need to know to make this change? How long should it take to change out the fogs?
Thanks in advance for any advice/recommendations.
bend down and look at the fogs, you will laugh at yourself for asking how to remove them(they are just held in by two scews).
-the fogs take 9006 so they be no problem whatsoever. just unscrew the fogs and they come right out. remove bulb and put in the new one.
I hear the PIAAs are nice but i gurantee you sooner than later you will be yearning for Hids or retrofit.
Difference is literally "Night and Day"
good luck
olddog
good luck
olddog
sparky3
07-05-08 02:12 AM
