GS400: Manual Shifting fm the Steering Wheel
Hello All,
As a 'new owner' of a '99 GS400, there is of course the option of up or down "M-Shifting" from the Steering Wheel -
How best to do this (?) For example, in the "M" Position, does the car actually go up and down through the gears normally as it does in "D" ?
Specifically I am thinking of the drive over California Highway-17 from Los Gatos to Santa Cruz. This is a curvy, windy tight 4-lane road approximately 20-miles in length with many ups-and-downs and speed reductions to 40mph on the tightest curves. One really has to stay-on-top of things, be focused and not drift-asleep driving this stretch, most especially going down-hill. Folks tend to drive this at their highest speed physically possible irrespective of the posted speed limit, which is either 50 or 55 on the straighter flat stretches through the Santa Cruz Mountains there.
It seems to me the up-and-down shifting available through the "M" position would be ideally suited to this application -
Any thoughts and comments would be greatly appreciated -
Incidentally, right now I am treating the hood (...the car is Black Onyx) with Turtle Wax' "Ice Claybar" and seem to be winning, especially on removing any final hints of oxidation remaing within the paint.
Thanks in advance
Thanks in advance
19x11.5 -51
well in the M position you control how you want to shift ... Lowest gear it will go is 2nd ... ... you click the thumb control on the steering wheel to change gears
Be careful doing this in curvy areas .... Your fingers will be down shifting and up shifting ... can lose position when your hands are bzy ... I was going 65-70 in turns and was under steering and worrying about that ....
I asked the original owner when I bought mine.....
welcome aboard and drive safe !
M will shift the gears just like you're in D. When you down shift to a gear, it will not surpass that gear, but if you use enough throttle, it will down-shift to a lower gear. Drive safely.
Yeah, be careful not to punch it thru a turn. It will downshift hard(especially with the torque of the V8) and you will spin out. It happened to me a few times when I was new to this car. Luckily I didn't hit anything during those yonder days. Even if you know how to control the car thru a slide/drift. The downshift is very abrubt and powerful. It's very difficult to maintain control in those situations. I've practiced numerous times in open parking lots and everytime it downshifted hard, the car became very unsettled and difficult to control. It was near impossible to get a controlled powerslide in those situations. My advice is to keep it in the lowest gear you plan on in that speed range. So even when you floor the pedal, it won't downshift a gear.
Many thanks for all the good advice...
- sounds like it simply relieves you of having to leave-the-steering-wheel, reach-down (...with the right hand) and down/up shift to get the engine-braking...
Hands remaining on the steering wheel to 'pinch' underneath to up-shift and/or push the "Down" button atop is the alternative -
I can see, however, that in the 'thick-of-things,' at-speed negotiating those curvy turns it can become challenging...
thanks again and what I'll probably do is use it sparingly if at all - there are a whole lot of huge, empty parking lots about...may give it a go this weekend -
Happy Labor Day to all
Hello All,
Thanks in advance
Thanks in advance
littleroo
07-30-07 09:41 PM
