Need to pass safety inspection,.....
Well I recently purchased a GS4 and was going over all the crap MD safety inspection involves and came across the high beams. Well long story short they don't come on, neither does the indicator on the instrument cluster. HIDs are ok but when I hit the high beams the fogs go out and only the HIDs light up. I changed the High beam bulbs checked the fuses. Still no luck any one have any other ideas?
Are the DRLs coming on? They're the high beams running at low power. If they come on, then your wiring is good. If not, then you probably have an open circuit somewhere.
JB
JB
Anything else I could check?
Forum Administrator
DRLs were added mid-year in 1999, so this test isn't a sure thing for him since (his signature says) his GS is a 99.
Forum Administrator
ok,.. I do have DRL's according to the original window sticker, but they do not come on. The high beams/DRL's don't come on at all. When fogs are on and I turn on the high beams the fogs go out. Any ideas on how to troubleshoot this would be greatly appreciated.
Thanks
Thanks
The 98 and early 99's that did not run the high-beams at half power for DLR had a small (194) bulb inside the high beam enclosure that comes on with the low beams.
Yeah, definitely need to ascertain whether you even have DRLs. (The little wedge bulbs are the parking lights). But, I *smell* a faulty relay. Either way, you need schematics for your car. There's a Toyota website where you can download the manual and schematics for $10/day. Search the forum. I think it's the TIS or TIIS or something similar. Good luck.
JB
JB
Fogs....
Hey Rare1,
I don't know about the high beam problem, but the fogs are supposed to go off when the high beams are on. Was that one of your concerns as well? That's normal, now about your high beam problem I hope someone else can chime in and help. Let us know how it turns out...
-Joe
JB
JB
Hey Rare1,
-Joe
-Joe
I really appreciate the help thanks everyone.
