MOMO install 101...
Caps and screws
The package contains several rubber caps, all with the same OUTER diameter matched to the INSIDE of the ****, but each rubber cap has a different INNER diameter, to match to a particular car's shift rod. The GS needs the cap with the smallest inner diameter.
There's also two packs of screws (short and shorter ) and a hex key wrench to tighten them. The silver ring on the left goes on the shift rod first and is tightened up on the **** after to hide the screw holes.
cap in ****
The shift **** goes down over the rubber cap, and the rubber cap SHOULD go all the way to the top of the ****. Here's the cap inside the first (short zebrano wood) **** I installed (after I'd take it off).
Fixing a cap
If the cap doesn't go all the way into the end of the ****, and it didn't on the knew tall zebrano ****, what I did is drill a hole through the end of the rubber cap while it was still in the ****:
(NOTE: This picture is 'rigged' - it actually shows the SHORT zebrano wood **** I had on before I put on the new tall one.)
install **** and screws
Once the **** is on, the (long) screws can be installed. DON'T SCREW JUST ONE IN ALL THE WAY. All that does it push the **** away from the shift rod on the other side. Screw in all three screws part way and then keep screwing each one in a bit more until they're tight.
Voila
Finally screw the bottom ring up onto the **** to cover the screws.
If you were paying attention, you'll notice I switched from the silver bottom ring to the black one that came with the short **** I first had on. I think the the black looks better.
Originally posted by Silver Ghozt
Bit, thanks, bud. I appreciate your posts. I still don't know how you got the screws to touch the shaft. I must have gotten a set with only the shortest screws. I have to contact Burien.
Z
Z
Mine only came with the shorter set of screws.
Also, mine only came with the very large diameter adaptors. The larger 3. The one that seems like will fit the GS and the next one isn't included.
Gonna ask Burien.
Originally posted by K10's-GS4
The MOMO **** looks great man!!! Where can I purchase one of those?
