HELP... i broke one of my lugs....
Old 10-02-07, 10:05 AM
greyBLITZ
greyBLITZ's Avatar
Originally Posted by BIGVIC23
so i purchased the hubcenteric rings on ebay for 9.99 plus 2.50 shipping and i got the stud at autozone for 1.sumthin.... ill start working as soon as i receive my rings.....
BTW!! is the absence of the hubcentric rings the reason why my car starts to shake as soon as i hit 55? didnt do it b4 the rims.
The absence of the hubcentric ring is one of the reasons that can contribute to the shaking. This is due to the wheels not being completely centered as it is only sitting on the studs which is very bad. At specific speeds this can cause a sort of harmonic vibration.
But the GS is notorious for having vibration problems at certain speeds, namely the 50-60 area I believe. There have been tons of threads about it and not many of them figure out the problem and have it solved. I'll try to find one for you though.
Old 10-02-07, 12:03 PM
PRSUIT460
PRSUIT460's Avatar
Always ALWAYS use a torque wrench.
Never use anti-seize on studs either, to those that do...
Old 10-02-07, 01:14 PM
Caoboy
Caoboy's Avatar
did you have your wheels balanced? if not, go do that. if yes, take it back to them and tell them that it's vibrating and they need to be rebalanced.
Old 10-02-07, 10:04 PM
marshun
marshun's Avatar
i've NEVER used hub centric rings for anything. the shaking sounds like another problem. im thinking alignment. might want to get that checked
shaft
11-15-13 01:10 PM
MIA IS250
01-18-12 05:17 PM
chrisvr6
GX - 1st Gen (2003-2009)
07-01-10 09:16 PM
handoverfi
01-21-09 05:19 PM
blkonblk17
Suspension and Brakes
25
07-19-07 04:06 AM
Quick Reply: HELP... i broke one of my lugs....
