The NOOB
The NOOB
What's up guys
I have been on the forum for awhile and love the site, but I just picked up a Silver/Grey 01 GS430 with 48,000 miles. The car is bone stock, when I picked it up it didn't even have tint on the windows and I live in AZ where it is hot as hell. The GS will not stay stock for long as I have a lot of plans for the car.
I just came from a 350Z that my friends and I built from the ground up.
The car made 550 whp and 508 foot pounds of torque at 12 psi on 91 octane
Engine & Performance
Greddy TDO5-18G Twin Turbos
HKS F-CON
HKS Knock Amp
HKS DLI Ignition
Fully Built SGP Long Block
Pauter Rods
CP Pistons .020 Over (8.5:1)
ARP Rod Bolts
ARP Main Studs
ARP Head Studs
JWT Upgraded Cams
JWT HD Valve Springs
Fuel Return System (Lines, Fitting, Rails)
Aeromotive Fuel Pressure Regulator
750cc Injectors
NGK Spark Plugs
Greddy Oil Pan
3 Inch JIC Full Titanium Exhaust
JIC Y-Pipe
Tail Wastgates
SGP Racing Ceramic Coated Wastegate Re-Location
APS Cat Delete Pipes
Greddy Front Mount
PWR Racing Radiator
Nismo Low Temp Thermostat
Greedy Breather Tank
Earl’s Oil Cooler
AAM 5/8 Plenum Spacer
Carbing Catch Can
Gozonta Heat Shield
Greddy Air Diversion Panel
Ground Wire Kit
Nismo Oil Cap
Z Toys Fluid Caps
Suspension & Braking
HKS RS Coilovers (30 Way Adjustable)
Wilwood 6-Piston Calipers
2 Piece Slotted Rotors
Stainless Braided Brake Lines(Front)
Ceramic Pads
Hotchkis Sway Bars
JIC Strut Bar
Drive Train
JWT 350z L/W Flywheel
RPS Max Street Clutch – 300ZXTT
SPL Solid Differential Mounts
3.3 Gear Swap
Nismo Differential Cover
Interior
Custom 4-point Cage
Takata 4-point Harness
HKS Navigator Pro
Blitz SBC I Color Boost Controller
Defi Gauges (Boost, EGT, Fuel Pressure) With Brain
Voodoo Shift ****
Blue LED’s
Custom Gauge Plate
Audio
Eclipse 5495 Head Unit
JL Audio 2 Channel Amp
Focal Separates
Sirius Satellite Radio
IPOD Adapter
Wheels
JAZ Trinity
19x8.5 Front, 19x9.5 Rear
Bridgestone Potenza
255/35/19 Front, 285/30/19 Rear
Exterior
Aerosync Front Bumper
Greddy Sides
Custom Hood
APR GTC-200 Adjustable Carbon wing
Color Matched Door Handles
Debadged
Shaved Rear Wiper
Sorry for the long post
HKS F-CON
HKS Knock Amp
HKS DLI Ignition
Pauter Rods
ARP Rod Bolts
ARP Main Studs
ARP Head Studs
JWT Upgraded Cams
750cc Injectors
NGK Spark Plugs
Greddy Oil Pan
JIC Y-Pipe
Tail Wastgates
Greddy Front Mount
PWR Racing Radiator
Earl’s Oil Cooler
Carbing Catch Can
Gozonta Heat Shield
Ground Wire Kit
Nismo Oil Cap
Z Toys Fluid Caps
Ceramic Pads
Hotchkis Sway Bars
JIC Strut Bar
Drive Train
3.3 Gear Swap
Interior
Custom 4-point Cage
HKS Navigator Pro
Voodoo Shift ****
Blue LED’s
Custom Gauge Plate
Audio
Focal Separates
IPOD Adapter
Wheels
JAZ Trinity
Bridgestone Potenza
Exterior
Greddy Sides
Custom Hood
Debadged
Shaved Rear Wiper
That's a really nice car you had there. The only thing I don't like is the wing but everything is hot to death. Honestly, unless I was starting a family, I would have never sold the Z for a 2GS, actually I would love to have both. But, Welcome to the Club and happy modding.
thanks guys, I had a lot of fun building the Z but I have wanted to build a 4 door car for a while. I have always loved the look of the 2nd Gen GS and thought that now would be a good time to move on from the Z.
Here is a photo of the G35 that I had before the Z
