Tie Rod rubbing on STOCK RIM?
I had this problem for a while, and my solution was to not turn my tire all teh way...I never knew what it was until today.
I had to go to my mechanic to get a flat fixed and decided to diagnose the problem and found that when I turn my wheel all the way to the left my inner part of the driver side rim rubs against my tie roddd!!!!!!!
Mechanic told me to just not turn the wheel all the way-- but of course thats not a solution for me.
I have 17inch stock chrome rims and have had my inner tie rod ends replaced about a month ago...
I'm not sure if anyone would have any suggestions for this considering everything is stock..but all ideas and potential solutions are welcome and greatly appreciated!!
--thanks
--thanks
--thanks
--thanks
Thanks,
Cuong
Hmmm, we are talking on aim right now..I'm not sure if that's it..but lets see if we can get some more input with a picture:
This is the problem Tie Rod End..that RUBS...it doesnt always rub, it is intermittent..so I think parts of it rub....maybe my rim is screwed up? (doubtful)
None the less, here is a picture of the problem on the drivers side:
they look like they are ok...
But It could be a possibility..
I guess when midterms are over Ima have to get my baby back up on hte lift...
If they arent installed properly...I dont think I'm ever going to my damn mechanic again...
these guys shud stick to taxi cabs! :-o
I dont know guys..
I keep thinking it is something else...
--But
I will try to compare my care next weekend with one of the other CL cars to see whats at work here!
--But
--but can you take a picture of your tie rod end too?!
so i can compare?
thanks man
i just dropped off my car to the shop that done my outer tie rods install and he said if they are installed backwards then the inside would rub the insides of the front wheels. so you most likely have a wrong tie rod the wrong side. i will be picking up the car after work so i can comment back when i do.
