For people with G35 wheels, do you use hub centric rings?
#47
I tried to order a set of hub centric rings for my wheel (350z 35th anniversary wheel 66.06mm -> 60.01mm) on 1010tire.com, but i got a reply from them and stated the hub centric rings won't work on OEM wheels, any ideas? thanks.
Heres the reply i got:
You recently placed an order with us for some hub centric rings, but there is a problem with the order. You left a note stating that these are for some OEM rims. Hub centric rings are designed for use with after market rims. After market wheels have a special "seat" machined into them for the hub ring to sit into. OEM wheels do not have this seat, so even if you get the size correct, they may not fit properly. If the rings do not sit flush, then the wheel may actually not sit flush on the hub of the vehicle and this will cause more vibration rather then less. As noted on our web site, we do not allow returns or exchanges on hub centric rings, so if you decide to proceed and they do not fit, you are stuck with them. Please reply to this E-mail and let us know if you want to proceed or if you prefer to cancel the order.
I am wondering if these center rings actually fit flush to the G35's 19"? Anyone has a picture of the back of these rims with the ring installed?
Also, I've found a set of poly locally here but it's 67.1 - 60.1. For people who posted with 67.1 installed, did it turn out ok or did you have to trim any?
Thanks,
#50
Great write up guys. I actually have the new 19" G37 Sport wheels sitting here. Haven't had any time to mount them. I will soon though. Thanks for the advice.
Anyone know if it's the same specs as the 19" G35?
Thanks.
Thanks.
#51
Were you able to find the hubcentric ring? what are they? what lug nuts do you use? thanks.
#56
Probably, it may be a better fit but I'm not sure. I just used the dremmel to just shave a little bit off for a better fit. It's been a while. I know it's a very snug fit.
vaki2
vaki2
#58
Am sorry that my sig does not say I own a set of G35 wheels.
I use the G35 as spares when my GF drives my car or when I travel back and forth between east and west coast of FL. I have these for about 2 years now. Here are pictures test fitted, before and after paint and also a couple of random pics:
http://www.softweb-creations.com/vak...gs/page_01.htm
The info I posted was what I bought when I got those rims.
BTW I also own a set of Vossens 20's which also are not in the sig.
http://www.softweb-creations.com/vak...ls/page_01.htm
vaki2
vaki2
#60
Got those from clublexus before they had to change their logo.
Another friend of mine made his own since he liked the original stickers better then the new ones.
vaki2
vaki2
