For people with G35 wheels, do you use hub centric rings?
#92
Brian are you asking about 10mm spacers front and rear? If so then that is hard to figure out without knowing your height or fender mods. G35 wheels are 33 or 30 offset depending if you are using the 8.5's or the 8s. Would need more info in order to give you better advise.
see my buddies infiniti is using that factory he says and i wanted to also but i thought for sure it would rub, i wonder about a 240/40/19. would i rub on this?
#95
yes vlad, 10mm front & rear. well, im gonna be lowered on megan coilovers (when i pay chris for them) and im using all 19x8's as i said with a 235/35/19 all the way around
#96
i kno im just makin sure , but does anyone have the staggered rays 19s on a 2gs without any shakin or vibrations with or without hubcentric rings or had it on without n after puttin the rings in it stopped. i just ordered it anyway ,id rather have it then not have it .
#97
#98
240/40 doesnt exist. Personally I would change the sizing of your tires. If u use the tire sizing calcon most site like 1010tire u will see a huge difference. Stock tire size on the17s on the gs is 235/45/17 on an 8" wheel. If you are looking for a less bulky sidewall I would even go to a 225 width. If it were up to me I would choose 225/35/19 or 235/35/19 and call it a day. As far as spacing them out 10mm I think that it should be fine, as a precaution I would trim the rear and just slightly roll up the li of the front of the front fender. But I dont think that it will be necessary specially if u go with 225s.
#99
oops im sorry vlad i meant 245/40/19 as thebean had also said.i dont have the 17's i have the OEM 16's. all the tires i have been pricing and looking at have been 235/35/19. i have NO intentions of doing any fender mods vlad so thats why i was asking about the 10mm spacers and my tire combo. if i go with the 235/35/19 would i have any issues? i think this is what im set on but its not 100%
if you just ordered them, why you still asking? just put them on and call it a day
225/55/16
Overall Diameter: 25.74 in
235/45/17
Overall Diameter: 25.32 in
225/35/19
Overall Diameter: 25.20 in
235/35/19
Overall Diameter: 25.47 in
245/40/19
Overall Diameter: 26.71 in
The closest in size to either stock tire would be the 235/35/19, however if you want to do no fender work and run a spacer I would choose the most narrow tires that you can utilize which would be a 225/35. Since my fenders havent been stock in years and I dont remember exactly what they can take, I know roughly. The proper way to decide what spacers if any you should go with you should put the 235/35/19 on and than make the proper measurements at you height and alignment specs.
#102
was quoted 135 a tire....
see them here, they look amazing Vlad
post # 15
https://www.clublexus.com/forums/gs-...35-wheels.html
post # 15
#105
With anything under 15mm you replace the studs. If I was using 10mm spacers I would go with H&R. Ichibia is another choice and they work with no problems, I am using the 15mms up front. But that is only because H&R doesnt make a 15mm spacer that has studs in the spacer.
