Vibration at 65-70MPH
i got the same problem..lol got my tires balance 4 times thinking it was just some dumbb *** at the local shop that didnt kno how to balance tires.. haha anyways check out the my caster arm bushings are worn and torn (not all the way) but could use some replacement for them tho.. order it today and we'll find out next week... to be continue......
going to da shop today for a check up..
seems like everyone has a different cure.
I had the normal steering wheel vibrations and i just replaced my Lower Ball joints and now its gone! so happy. Mind you after i left the dealership after they replaced it i still felt the vibrations but then they called me back because they forgot to put the hub centric rings back on.
once the hub rings were back on the vibrations have disappeared.
Its a combo of hub rings and ball joints for me because i had just the hub rings before with my 19s and they got rid of about 20% vibrations and the ball joints pretty much got rid of the rest.
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
Got rid of most of the vibrations this weekend. Was having trouble finding hub rings that fit. Third set worked. Had to have them sent to Phoenix to be lathed down to fit. My wheels have the same center bore as a Mercedes I was told. The first rings were 73 mm,too big,2nd set 67mm,too big.New ones are made of aluminum I believe.
here guys...is a HUGE post bout stuff to fix them in both these older posts
https://www.clublexus.com/forums/gs-...nes-fixed.html
https://www.clublexus.com/forums/gs-...djustment.html
