3 questions
3 questions
1. Does anyone know how to fix a p0440 engine code? 2. Has anyone ever used universal cats on a 98-05 gs300? 3. Does anyone know where i can find a cheap driver side door lock actuator? I just bought the car a few days ago and im having an extreme case of buyers remorse. email me at fast4doorgtp@hotmail.com
PM GSoup. He has an aftermarket cat on his car. He's turboed, but I dont see why you can't use one on a stock GS300.
Cheapest place for a new actuator is from Carson Toyota (One of clublexus' vendor). It's about $200+ shipping.
Anyways, p0430 either means your oxygen sensor or cat may need replacement. lexus can see if your oxygen sensor is working properly by running a test. However, the diagnostic test is $90 or so. You might as well get an oxygen sensor for about the same price.
If it ends up being your cat they are covered under a 8 year 80k warranty if your car fits under that time frame. Seems like most cases end up being a O2 sensor though. One easy way to tell is switch the plugs from one sensor to another and see if the code jumps to the other bank. Could also be a simple as a exhaust leak. http://www.epa.gov/OMS/consumer/warr95fs.txt
vstyle444
06-03-08 01:50 PM
