Shifter Stuck in Park? Any ideas?
Old 11-01-07, 12:20 PM
RADTCB
RADTCB's Avatar
Default Shifter Stuck in Park? Any ideas?
My 99 GS300, shifter is Stuck in Park, and can not move.
I was told it might be a sensor, any ideas what I can do to fix.
Thanks!
Old 11-01-07, 01:15 PM
Aristo300
Aristo300's Avatar
Have you tried pressing in the release [while simultaneously trying to pull the shifter out of park] that's to the left of the gate?
Old 11-01-07, 01:37 PM
quy2k
quy2k's Avatar
https://www.clublexus.com/forums/sho...ft+lock&page=2
try this. worked for me.
Old 11-01-07, 07:53 PM
swat1727
swat1727's Avatar
most of the time, one of ur fuse is popped. ex: horn. that will make ur shifter stuck. forcing u to replace the fuse before u move on.
Old 11-01-07, 08:15 PM
Downfall75
Downfall75's Avatar
When that happens to me, I just pump the brakes and try to shift until it moves.
Old 11-01-07, 08:27 PM
DJ TANTRA
DJ TANTRA's Avatar
any luck??!
Old 11-01-07, 08:52 PM
qgoat
qgoat's Avatar
Probably gonna be your brakeswitch. Should be located on your brake pedal stem or arm.
Techron (01-12-17)
Old 11-01-07, 09:13 PM
TAMR_GUS98
TAMR_GUS98's Avatar
Originally Posted by quy2k
Yeah, that would be the shift lock override. Still would need to see what is keeping you from shifting out of park though.
LOL. I was gonna ask if your brake light works. If your brake lights work, then it might be the Shift Lock Control ECU.
Good luck!
-Will
Old 11-02-07, 02:00 PM
NBart
NBart's Avatar
Are you sure about this one? Last time my radio fuse popped i was still able to drive home and replace it.
Old 11-02-07, 02:19 PM
JeffTsai
JeffTsai's Avatar
He was probably referring to like a brake light fuse or **** control ecu fuse....something to that extent.
Old 11-02-07, 06:49 PM
swat1727
swat1727's Avatar
yeah, it's mostly safty related fuses. horn, brake, lights etc. not sure exactly which ones will cause the shifter to get stuck. but i know horn for sure, because that happened to me about 6 month ago. i got freaked out lol. but once i replaced the fuse, everything works normal again.
Old 10-20-18, 03:16 PM
Shareeiif
Shareeiif's Avatar
Default Lexus LS 430
I have the same problem with LS 430 . To release the gear from the park I have to pump the pedal than it will get released and brake lights turns off when I press the brake completely.
Old 08-18-20, 12:27 PM
DARIELISM
DARIELISM's Avatar
Has anybody provided a solution to this? I'm having such issue with the IS250 '06
Swich
03-21-19 10:57 AM
Abnush
01-09-19 11:54 PM
2jSC3
Performance & Maintenance
11-21-15 05:33 PM
Caniac14
12-18-14 06:41 AM
Quick Reply: Shifter Stuck in Park? Any ideas?
