Weird noises when reving
If I'm revving my engine at idle, and I go past 2rpms, and release the pedal, I can hear a not so very loud clinking sound. It basically sounds like either the timing belts are almost done, or there's something else. I really do not know what it may be.
Any ideas?
Any ideas?
Location: A middle sized town in the middle of the Midwest
Well first off, if your car has over 90,000 and the timeing belt hasnt been changed its very important you do so on the GS400 because if it breaks it will cause big problems.
So have you been able to pin point a location of the noise?
Could be a blown cat. They wear down overtime and eventually the mesh insides breaks apart and then rattles around.
Good Luck,
-Will
itisme1760
03-13-16 09:09 AM
gabzor
09-15-12 07:02 AM
