I tried this but was unsucessful. Main reason is because the foglight front lens is wavy. No way to get rid of those. I tried sanding but no luck, it's some incredibly hard material...possibly glass but I can't confirm that. I ended up wasting a set of fogs because of the failed sanding. If you can somehow fabricate a thick curved piece of Lexan to fit on there then you should be good to go. A small projector such as a 1inch unit will fit in there. I was actually gonna use the 350z HID projector. I abandoned the project after I was unable to get the waves out of the lenses.
If you want to attempt it, then I have a set of fogs for sale here. One has a sanded up lens. The other one is still in good condition.
I'm still trying to figure this one out. there is plenty of room behind the passenger side fog light for a projector to fit, but the windshield wiper fluid tank is behind the driver side foglight leaving not enough space behind the foglight for the projector to stick out of the back. I'm trying to find the 3rd gen GS projectors because the bulbs in those go in from the side.
I think jp makes clear fogs..if your baller enough to buy those and then retrofit some hid projectors in there then go for it. I think a member has already done this.
I did, if you referring to the cost of the fogs.. i factored in the cost of a set of fogs and the projectors themselves. But i guess... i mean who wants to give a peice of **** $100, plus my time and effort to replace that *****.
ay-nako's fog has a 350z projector in it. he is not finished but you may wanna ask him how far along he is on the project.
yeah by no means is it easy i wanted to have a clean look but then a friend actually gave me a set of 350 z projectors!
