Q about the gas talk door
So not sure what haooened.. but my lever won't work. Probably because I think something broke that releases the door open.. Can anyone help?? Pics so i can see whT I might be minisg... I did find a small metal clip that looks like it came out when I opened it...
Thanks
Rock
Thanks
Rock
Rock, pop the gas door using the release in the trunk. I believe it's located on the driver's side of the trunk (basically the other side of the gas door inside your trunk), it's a little tab attached to a wire, the tab has a pic of a gas can or something similiar on it. You can hopefully access your gas tank via this method and might be able to find out what's causing the problem. Hope this helps, I know you don't want to run out of gas
gas door
Hey thanks for the quick reply.. I unfortunately opened it without knowing that because I needed to get gas last night.. So now I know I broke something with the door.. Can anyone post some pics so I can see what i might be missing/..
Thanks,,
Rock
Thanks,,
Rock
THE_CEO
SC- 1st Gen (1992-2000)
02-04-03 06:40 PM
