DIY wheel bearings
Has anyone changed a (front) wheel bearing by themselves?
I asked Lexus but they want some outrageous amount again. I thought I could get away by renting a press from Pepboys or Autozone but I guess I need a more powerful machine press from what I heard.
If anyone has changed the wheel bearings on a GS, please tell me if this is a DIY or not.
Didn't think that the Lexus wheel bearings were really a maintenance item...
My MR2 has 193,000 miles and still has the OE wheel bearings.
They're pretty stout, but of course we have mild winters here in CA.
Never occurred to me to change them... no noise, no worries!
and yes, these wheel bearings do go bad. maybe b/c of the salt.
It's DIY-able, but only if you have a press. I dont recommend a hammer at all
. you'll need to carefully take your time to press in the hub bearings. The slightest offset will result in vibration and unstability. If you have a lot of time, it's not that bad. But you will cuss and yell because there will always be a part where you're stuck.
I've been searching and found this thread. So as GSteg said, it's DIY-able as long as you have a 12t hydralic press (which I wouldn't trust myself with).
I may just bite my tongue and take this one to the dealership if I can't find a friend with a shop that has a press like this.
Using a hydraulic press is just like using a floor jack, except upside down. Just dont rush and make sure everything is aligned. But if you dont have a friend who has a press, just bring your knuckle and everything you need to a mechanic shop and they'll charge you a very small fee to press it in.
I hope this helps,
Gears
