View Poll Results: How much ATF does a 2001 gs300 need for drain and refill?
2qt
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
18
50.00%
4qt
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
30.56%
other (please let me know how much)
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
19.44%
Voters: 36. You may not vote on this poll
How much ATF do i need for drain and refill?
#31
I just did a drain/refill.
I measured ~2 qt drained and refilled the same amount (to avoid the issues associated with the dipstick after refilling).
Miles when purchased: 30,000.
Current miles: 104,000.
The fluid appeared to be in excellent shape, a murky purple.
FYI, my dad ran his 1990 LS 400 to 330,000 miles without changing the transmission fluid and never had any problems or noticed any issues. He has done two drains/refills since then per my suggestion, but I don't think he's noticed any effects.
https://www.clublexus.com/forums/gs-...-in-gs430.html
Brian
'02 GS 430
naluloa (07-05-24)
#32
From the service manual for a 2002 GS430:
Automatic transmission fluid (2JZ-GE)
Dry fill 8.2 liters (8.7 US qts, 7.2 Imp. qts)
Drain and refill 2.0 liters (2.1 US qts, 1.8 Imp. qts)
Automatic transmission fluid (3UZ-FE)
Dry fill 8.9 liters (9.4 US qts, 7.8 Imp. qts)
Drain and refill 1.8 liters (1.9 US qts, 1.6 Imp. qts)
thanks so much, this is what i was looking for all over the site and couldn't find it easily.
handogg
08-02-17 05:35 PM
