Headlight - Shuts Off
11-21-07, 12:54 PM
I am having an issue with my HIDs on my GS.
When I turn the HIDs on they come on. And then 5 minutes later the right head light shuts down.
Did this happen to anyone else? Do I need to change my bulbs or is there a wiring issue with my car?
Please help.
Thanks
Dave
11-21-07, 12:58 PM
Seems like a problem with the ballast. My friend has a TL that sometimes does it. When he turns on the headlights, one of it won't come on. Then he turns it off and back on and it works.
11-21-07, 12:59 PM
Would this be covered under warrenty? I but my car used at the lexus dealer. just wondering if this would be covered under the 3 yr warrenty
11-21-07, 01:35 PM
Should be. Only part on the headlights I was unable to warranty was the housing when it got condinsation behind the lens. Good luck
11-21-07, 02:16 PM
Switch the bulbs to the other side and see if it has the same problem. If it does, it's the ballast, If not, it's the bulb.
11-21-07, 04:20 PM
19x11.5 -51
possible light going out ... or loose wire .. or connection ...
happens alot with Hids ballests
11-24-07, 02:32 PM
do you guys know of a good website to buy Replacement HID bulbs
11-24-07, 04:05 PM
Same thing happen to me..
11-25-07, 11:00 AM
Quote:
Originally Posted by
nyczdave
i gave up on sites and got a OEM Philips pair, new for roughly $70 shipped from cheabay. PM me if you need that seller.
jiimpman23
05-23-13 09:51 PM
duffer649
ES - 5th Gen (2007-2012)
16
10-26-12 03:40 AM
ApokC
10-17-10 09:32 PM
Gordy35
05-20-08 07:25 PM
ghd8989
07-23-07 11:47 AM
