VSC + VSC OFF + Check Engine lights appeared on the dashboard
Old 11-25-07, 05:54 PM
masboy
masboy's Avatar
Default VSC + VSC OFF + Check Engine lights appeared on the dashboard
These 3 lights (VSC + VSC OFF + Check Engine lights) are came up on the dashboard at the same time this afternoon, I wonder what the problem would be ? Anybody had this kind of 3-lights before ?
I hope it got nothing to do with intake that i've installed few months ago. I don't want hear "you void our lexus warranty because you install intake" tomorrow in dealer
Old 11-25-07, 10:04 PM
kit cat
kit cat's Avatar
my bet would be the MAF.
Old 11-25-07, 11:37 PM
tuterz
tuterz's Avatar
vsc trac and vsc off turning on all the time?... or just when moving.. or stopping?
Old 11-26-07, 03:50 AM
War Eagle!
War Eagle!'s Avatar
I bet your battery or alternator is having issues. I've seen similar light combinations on my land cruiser when the battery went out.
Old 12-05-07, 07:28 AM
masboy
masboy's Avatar
Default MAF indeed
damn, how do you know it's MAF ? IT IS MAF. Just got replaced by warranty.
tuterz : all the time.
i'm start thinking to take out the SRT intake replace with something else (affordable) that will help gain power....hmm what would that be ? anybody ?
Old 12-05-07, 10:11 AM
cptnron
cptnron's Avatar
This is too crazy. The exact same thing is happening to me so I logged on to search for the problem and you are posting the same topic. Before all the lights went off, my brake light was going off. My buddy who has an SC told me to check the brake fluid. It was low and I topped it off and it worked for a little while, but now it comes back with all the warning lights sometimes. It seems to be better when the car is warm and I pump the brakes. I'm feeling like I should bleed the brakes or maybe even replace the pads. Any hyelp with past experience would be great.
Old 12-05-07, 02:56 PM
Gs430Boi
Gs430Boi's Avatar
ok when you installed the air intake did you reset the battery after the install cause the extra amount of air can set it off
MAF = mass air flow sensor its the sensor that is right beside the air filter
Old 12-05-07, 02:57 PM
Gs430Boi
Gs430Boi's Avatar
to reset light you would just need to unplug negative from the battery and set off for 2 min and light should go away
Old 12-05-07, 03:46 PM
kit cat
kit cat's Avatar
I'm just that good...jk. I'm not that mechanically inclined compared to others but you said you changed the intake and I had the same problem with VSC/VSC off/CEL and just cleaned the MAF and throttle and it cleared.
Old 12-06-07, 07:14 AM
cptnron
cptnron's Avatar
My code was 1128 which is the MAF. I cleaned it off and it cleared the warning lights. My brake fluid problem was completely unrelated but just happened to come up at the same time Thanks guys!
Old 12-06-07, 06:58 PM
dmizock
dmizock's Avatar
My lights just came on. Pardon me for being stupid, but is the MAF the intake air filter? Mine is definitely dirty.
Old 12-07-07, 11:35 PM
drewmack
drewmack's Avatar
Got those lights today and I know for a fact I am having alternator issues. Noticed the alt issues yesterday, now the lights today.
Old 12-07-07, 11:47 PM
semdaddy
semdaddy's Avatar
ur mass air flow is black and its next to the filter the part has a sticker on it sayin toyota
Attached Thumbnails VSC + VSC OFF + Check Engine lights appeared on the dashboard-aadd.jpg
Old 12-08-07, 11:02 AM
dmizock
dmizock's Avatar
Thanks so much for the response. I've got an SC430 and my "stupidity" had me go out and get a new air filter. Voila! All the warning lights went out! Go figure!
Old 12-08-07, 08:38 PM
masboy
masboy's Avatar
thanks semdaddy....
so how to clean that MAF then ? just wipe it out ? and how to clean the "throttle" ? sorry, im not a tech-car-guy....
thanks
Quick Reply: VSC + VSC OFF + Check Engine lights appeared on the dashboard
