wheel spacers disadvantage?
Does anyone know if there is any disadvantage of using the wheel spacers? I am looking for a brake upgrade and need the wheel spacers to clear the 4 piston clipper for my winter 17" tires?
will the wheel spacer cause uneven wear on tires? meaning innner tire wear out faster? cause the wheel will be out more than the factory spec.
Will the blance be easily off on the wheel since the wheel spacer is a parts that bolt between the brake and the wheel?
thanks
thanks
Here are a couple good threads to help answer your question on spacers.. I'm still pondering this myself.. Anyways here are the links that might help answer this for you..
https://www.clublexus.com/forums/showthread.php?s=&threadid
https://www.clublexus.com/forums/sho...hlight=Spacers
