Vsc-abs-vsc Off/plz Help
Hello everyone,
PLZZZZZZZZZZ HELP NEEDED ASAP
Need HELP again…..I have a 2000 GS400….Drove to work today got back home parked the car everything was fine but after an hour when I started the car again after the car started all lights on the dash went away except for three lights….now three lights stay on my dash and they are VSC, ABS & VCS OFF…..Any idea guys what is wrong with my car…I called one mechanic and he is telling me that maybe it's the Sensors and quoting me $300.00 for each sensor….Any advise & help would be highly appreciated…….
Thanks in advance…….
First thing to do is to inspect to see if the plugs are plug in snuggly. Then check to see if the sensor itself is secured down to the knuckle securely. After that, make sure the sensor is clean where it reads off of the splines in the knuckle. Lastly, after all of these steps don't work, remove the lower front splash guard and the liners and remove the plug where the sensors is plug in and take a multimeter and measure the resistance. It should be something like 1.6-1.7 Ohms I believe.
MAF = Mass Air Flow...
How would that have to do with..
VSC = Vehicle Skid Control
ABS = Anti-locking Braking System?
I don't know what the problem might be...but did you try doing a search?
I am pretty sure I have come across a few threads that discuss the same problem you are having...
Thankx a lot for response guys...now here is the situtation.....same night the evening the lights came on just to check i started the car again and the lights were gone.....next morning which means yesterday morning i started the car and lights were gone everything normal now....but when i was driving the car for the first about 15 to 20mins when i was applying brakes the ABS was coming on but then after a while everything went back to normal.....someone mentioned maybe i need new battery as for the battery i got new battery about 1year ago from lexus dealer ......as i mentioned the car is normal no lights on but was weired the way it was acting for a while this morning regural brakes and ABC was coming on for no reason you know.......Any idea? Advise? what you guys think i should do now? sorry guys i am not good with cars when come to mechanical issues & i dont want any mechanic to rip me off......
Thanks a lot for your help
There are few threads that tell you. I have a GS430 "01" and my VSC VSC Off came on as well. I changed my MAF and the VSC VSC off turned off. Take a look at one of the threads that say VSC VSC LIGHTS on and it should help.
If your brake pads are getting down, your brake fluid will be low so check that first. If that doesn't fix it, take it to an autoparts store or someone with an error code reader to see what the car is trying to tell you.
Bro -- If it was your batteries...while you are driving..your battery light wud come on..and your lights wud dim out...if your stereo was ont hat wud flicker on off...
and as soon as u increased throttle...your battery shud have gottena boost and all that wuda gone away...
I dont think u mentioned ur battey ligght coming on so I dont think it is that...
