15K service
I think
Replace engine oil and filter
Rotate tires
Inspect engine drive belts and hoses
Replace engine coolant
Replace engine air filter
Inspect/replace air conditioning filter
Inspect exhaust pipes and mountings
Inspect steering linkages and steering rack and pinion
Inspect fuel lines and connections, fuel tank vapor vent system hoses,
fuel tank blend
Inspect drive shaft boots (re-torque flange bolts)
Replace transmission fluid
Replace differential oil
Lubricate front drive shaft bushing
Inspect height control suspension
Inspect body condition
Inspect chassis nuts and bolts
Inspect wiper blades
Road test vehicle
Clean vehicle
Inspect tire pressure and tire wear
Inspect/correct all fluid levels
Replace brake fluid
Inspect fuel tank cap gasket
Inspect brake pads, discs, lines and hoses
Inspect ball joints and dust covers
this is for the 30k, the only list I have handy. Could be the same. They charged me about the same.
Rotate tires
fuel tank blend
Road test vehicle
Clean vehicle
Replace brake fluid
rclab1
09-15-15 03:29 AM
