Fuel injection cleaner
I also had my fuel injectors cleaned, the right way. This was not done by just adding some Pep Boys injector cleaner into the tank. This was done properly, by adding Run-Rite directly into the fuel line straight through the injector, and running the engine at about 1500 rpms intermittently with idle for 35 minutes to clean thoroughly. I saw smoke billowing out of my exhaust and could tell the effect of the cleaning agent. On my drive home, my car has signigicantly smoother acceleration, smoother start up, and in it feels a little quicker through the upper range of RPMs. I also had them clean my throttle body, on second thought, I can do that myself next time since they didn't do anything that I couldn't have done (thankfully didn't charge much for it either). Many thanks to Sean (DASHOCKER) for setting this up, and even though I didn't get the maximum benefit of group pricing (since 1 car isn't considered a group ) It was still cheaper to have this done here than anywhere else, and they did a great job.https://www.clublexus.com/forums/sho...ht=AMSOIL+MEET
http://www.run-ritestore.com/StoreFront.bok
Has anyone done this recently?
Always run Top tier gas(shell, exxon, google top tier gas)! Run Shell in my vehicles and over hundred of thousands miles never had any injector problems. All top tier gas are high detergent fuels. Use Chevron Techtron fuel additive every 3k to 5k. Should not have problems with needing fuel injection cleaning. Are you having issues that make you think injectors are dirty?
Hey, it deleted my text reply for some reason. I was saying that I like doing preventative maintenance since that car is almost 20 years old. I run shell vpower and sunoco premium, and occasionally use that Lucas. I am researching cleaning the fuel injectors because theres nothing really else i can do to my car at this point, i've done almost everything already.
