Fuel injection cleaner
Old 01-01-08, 08:32 PM
Shawnmack
Shawnmack's Avatar
Default Fuel injection cleaner
Have anybody ever went to the Dealership to have their fuel system cleaned. I got a coupon from Hendrick Lexus to get it done for $99.99. What does it actually clean?
Old 01-01-08, 08:39 PM
Johnny Rad
Johnny Rad's Avatar
Any merit to "do it yourself" (DIY) bottles of fuel injector cleaner?
Old 01-01-08, 08:42 PM
Shawnmack
Shawnmack's Avatar
Naw it's not the bottles that you buy at Autozone. they go through your Injectors some how and clean the whole system.
QLex300 (12-25-21)
Old 01-01-08, 09:19 PM
GSteg
GSteg's Avatar
I just had mine done..
It's basically the same if you're putting the solution in the gas tank. The only difference is that it's more concentrated when you run it directly to the fuel rail. Plus, you dont have to wait for a full tank to be empty get the same effect. You would need a good amount of cleaner in the gas tank to get the same concentration as if you were to run it through the fuel injector cleaner canister.
I used lucas fuel injector cleaner (found at autozone) mixed with gasoline in a 50/50 concentration. My injectors were ticking pretty loud, but after the cleaner was performed, the lubrication in the lucas cleaner made everything quieter. Plus I got rid of the rough idle I had. I'm going to see if my fuel economy is restored though, because I've been getting 14/18 mpg.
The cleaner itself is no different really. You can use most cleaners. It's just the process that makes the cleaner work more effectively (and quicker). Smoke was coming out of my tailpipe like crazy. Talk about carbon build-up
QLex300 (12-25-21)
Old 01-02-08, 05:41 AM
TruPlaya26
TruPlaya26's Avatar
Don't think I need to do this yet, but around what mileage is the best time to get the injectors cleaned? Just thought it would be good to know for future reference
Old 01-02-08, 05:52 AM
MrG4Life
MrG4Life's Avatar
That's a good question. I've only been putting the fuel system/injector cleaner every time I get my oil changed. Makes me wonder if putting this in is good enough to clean the fuel system or at some point should I have my car brought in to be professionally cleaned.
Old 01-02-08, 06:59 AM
DASHOCKER
DASHOCKER's Avatar
The proffessional fuel injection service should be completed every 15k. This service consist of 4 step process to get the job done. The bottle injector cleaner is just one out of the 4 steps.
Old 01-02-08, 09:04 AM
TruPlaya26
TruPlaya26's Avatar
cool, thanks
Old 01-02-08, 04:10 PM
HKS GS300
HKS GS300's Avatar
i used to work for a lexus dealer and we would clean the tb with a chemical cleaner, add an additive in the gas, and then run a injector cleaner through a vacum source. so it chemically cleaned the injector ports along with your tb.
Old 01-02-08, 05:19 PM
Och
Och's Avatar
Whats a good place to perform such service in NYC area? I don't trust Lexus dealers, particulary the local Bay Ridge Lexus, I think they will just charge a buttload of money and wont do a complete procedure, probably just add some BG44K to the fuel tank and that's it.
Old 01-03-08, 06:04 AM
DASHOCKER
DASHOCKER's Avatar
Info pm'd.
Old 01-03-08, 06:05 AM
Shawnmack
Shawnmack's Avatar
How much was it to get this done? Is 99.99 to much
Old 01-03-08, 06:12 AM
DASHOCKER
DASHOCKER's Avatar
This is what the 4 step process consists of
[QUOTE]
Complete fuel system cleaning involves
up to 4 different steps. We offer different
products for each step depending upon
your specific needs:
STEP #1: Fuel Treatment
1001, 1427, 1512
STEP #2: Oil System Treatment
1002, 4300
STEP #3: Intake Cleaning
1003, 1294, 1295, 1296
STEP #4: Throttle Body Cleaning
1287, 1293, 9710
1001, 1427, 1512
Run-Rite Multi-Step
Fuel System Cleaning Kits
REQUEST INFO & PRICING
RECOMMENDED: Every 15,000 miles or annually.
Improves Fuel Economy
Reduces Emissions
Restores Lost Power
& Performance
Improves Drivability
Available in 2, 3 and 4 step kits, the Run-Rite formula is proven to remove carbon buildup from injectors, valves and combustion chambers. It loosens and removes gums, coking, dirt and deposits from the engine to provide better performance and fuel economy in modern engines and fuel systems.
Run-Rite formulas are LOW VOC COMPLIANT. They also DO NOT CONTAIN ALCOHOL or METHANOL, and utilize the finest detergent additives available. Run-Rite is oxygen sensor safe, won’t harm coated or sensitive parts, and can be used on all gasoline powered combustion engines. This includes multec and “pintle-less” injectors. Run-Rite cleans safely, quickly and effectively.
For Professional Use Only. http://www.run-rite.com/industry/fuel_runrite.html
Old 01-03-08, 10:38 AM
MrG4Life
MrG4Life's Avatar
Thanks for the wealth of info SHOCKER. I've never had this done before to any car that I've owned. Besides maintenance reasons, did you feel any difference in the car in terms of performance after yours was done?
Old 01-03-08, 11:05 AM
TruPlaya26
TruPlaya26's Avatar
I'm going to have the 45k service performed soon, is this included in it if i go to the stealership?
Quick Reply: Fuel injection cleaner
