Did you get them from memoryfab? If so, I've been waiting for someone to buy those. I was actually thinking about them myself.
Those offsets will fit fine if you run the right tire sizes and add enough camber. You might want a spacer in the rear if you want to get more flush.
Yea i did get them from them. they are just 30min drive from my house. What tire size should i get? i want to get 275/30r19 but i think it might rub so i will start with a 265 first on the rear.
I think a 265 would work in the rear to be safe. I know that a +38 offset won't need fender mods with a 275. For the front you'll probably need a 225/35. That's what I'm running with +23 offset and it still rubs a bit. Hope your Daizen spring setup will get you low enough.
