Strange plug under centre console
Old 01-12-08 | 04:09 AM
lexesive's Avatar
lexesive
Default Strange plug under centre console
Anybody know what this aerial type connector is for, found it under the centre console in my gen2, seems to be OEM and goes towards the rear of the car?
Old 01-12-08 | 05:51 AM
phillygs3's Avatar
phillygs3
are you the first owner?
Old 01-12-08 | 06:22 AM
kit cat's Avatar
kit cat
I had a phone there but my plug didn't look like that.
sorry, can't help.
Old 01-12-08 | 09:20 AM
j0xxx's Avatar
j0xxx
thats part of the cell phone that was originally in there
Old 01-12-08 | 10:06 AM
JeffTsai's Avatar
JeffTsai
Yeah like joxx said. It's the cell phone antenna wire that's built into the car.
Old 01-12-08 | 01:33 PM
lexesive's Avatar
lexesive
Thanx for the replys, I sort of thought thats what it was, do you reckon the actual aerial is at the other end of the cable hidden somewhere like the satnav aerial
Have to go and see how I can use it with my phone if it is
Old 01-13-08 | 10:47 AM
Kansas's Avatar
Kansas
In our 2000 LS400, the antenna coax cable under the center console runs back to the right side of the truck under the removable floor panel. There is a second coax cable that runs from the phone antenna imprinted on the inside of the LS400 rear window to the same area in the trunk. Connecting the two coax cables in the trunk together allows the under console antenna connector to be used with an aftermarket phone kit.
All U.S. spec 95-00 LS400 cars have a phone antenna imprinted on the inside of the back window -- I don't know about other Lexus years or models or what the setup would be on Oz cars.
I use the imprinted rear window phone antenna with my old aftermarket Nokia CARK-91 phone kit but I do not know what frequencies the antenna supports. So far it has not mattered since our old phones support both analog and GSM. Since analog phone service is being withdrawn in the U.S. this year, I need to check on what frequencies the antenna supports since I suspect that our phones are kicking into analog mode when in the car kit's phone cradle.
Also on U.S. 95-00 LS400 is a mute pin under the center console near the antenna coax cable. On my 2000 LS, the mute pin is the front center pin in the six pin connector -- the audio system mutes automatically when a call is received or when I make a call either with a voice command or by using the phone's numeric keypad. (The connector is somewhat different on 95-97 cars but there is still a mute pin.) It is likely that other Lexus cars of the same vintage also have a mute pin under the console.
Eventually we will abandon our old GSM/analog phones and install phone kits of newer technology - perhaps Bluetooth - in our cars using the same power, mute, ground and speaker connections.
drewkaree
17
07-29-19 11:32 AM
MERXUS
SC- 1st Gen (1992-2000)
12
04-12-09 12:28 AM
JAbrams
01-02-07 08:03 AM
spinedoc
07-02-01 06:37 PM
spinedoc
06-18-01 07:13 AM
