License plate light install
Ok One last question. How do get to the license plate lights? I recently when to Super Autobacs and purchased the bulbs ($9 for matrix single bulb kit and $25 for a premium set with 6 bulbs) and am not sure how to install them, do you go in through the back underneath the carpet? As always any info is much apreciated. Thanks
SoCal Cyco: Yes you have to remove just apart of the trunk lining. There are these little plastic screws you can take out with a flathead. Just take off the ones that will allow you to peel back the lining a bit to get to them. After that, it's a bayonet twist type to get to the bulb.
Bumper is Mode Parfume and lights are probably Sonar. You can get the latter from www.l-tunedparts.com
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
This should do the trick..
This is the LED Bulb breakdown based on the bulbs that superbrightleds.com sells..
2rear door bottom light - polarg m4 -- LED 194 WEDGE
2rear passenger dome light - polarg m4-- LED 194 WEDGE
2front door bottom light - polarg m4-- LED 194 WEDGE
1trunk light - polarg m4 – LED 194 WEDGE
2rear license plate - polarg m4 - LED 194 WEDGE
1front central dome light - polarg m16 – LED DE3175 (30X10MM) FESTOON BULB
2front map light - polarg m17 -- LED BA9
2footwell - (not sure of polarg)-- LED #74
1glove box – (not sure of polarg) --LED #74
1ignition – (not sure of polarg) --LED #74
4 vanity mirror - polarg-m24 --LED DE3022 (8X28mm)
So you need two 194 bulbs...
Here is hte page...
Pick what you want and wat will fit
http://www.superbrightleds.com/cgi-b...e/commerce.cgi
Let me know if you have anymore questions...
I dont think the 12-led 194 bulbs will fit there..but I'm not sure...9 led shud be enough..or hte wide angle bulb!
Goodluck!
Here is hte page...
Goodluck!
Thank you very much for the fitting numbers! You made it simple
thaiflip
07-11-05 07:30 AM
