Looking for 12V switched source in trunk
Hello,
I am looking for a 12V switched source in the trunk to power a device that consumes only 1-2AMP Max.
I really do not want to rip the whole interior apart to run a wire just for this small part.
Any idea what source i am tap to power up this 12V 1-2AMP device?
Thank you
Thank you
If you can't find a wire in the trunk, getting it from the center console is the next best thing. Just remove the rear seats and part of the center console and you got yourself a clear path to run a wire. The only difficult part of this is feeding the wire under the carpet, which is not even that hard.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Check your PM please.
DaveGS4,
Thanks for the Info.
Anyway, I guess i have to take my interior apart again to run the 12V switched for this low power device (1AMP).
If you guys are woundering, I have installed a eclipse DD and i'm using this 12V source for the reverse camera. The 6V Output from the eclipse DD reverse camera will trigger the relay; thus allowing the 12V to activate the aftermarket reverse camera.
