GS3 Rim fitment Question
Looking at some rims that are 20X8.5 35 offset for front and 20x10 38 offset for rear. Will these fit without pulling or cutting and with a drop of Tanabe DF210 springs? Also what is the best size tire for this setup.
I am always thinking everything is for a GS4
On your GS3 you can actually fit a 245/35 in front and up to 275/30 maybe a 35 if you like. Less drop than the DFs for the GS4
but to be on the safe side, the previous suggested sizes will not rub at all even with people in the car.
![Rock On](https://www.clublexus.com/forums/images/smilies/rockon.gif)
I just switched from H&R springs to the DFs on my GS3. Wish the drop was the same as the GS4 with DFs though.
My wheel setup is as follows:
20x8.5" +35 245/35/20
20x10" +40 275/30/20
Yokohama S.Drives
I repositioned the plastic liner in the fronts by tucking it behind the fender tabs/flange. I rolled the font fenders slightly.
Even then - The only thing that rubs in the front is the plastic liner when I make a turn, but a heatgun will most likely solve this. The rears rub only when I hit a big lump on the freeway. I plan on shaving the rear fenders later.
For your situation, I think +38 in the rears will work but you're probably gonna have to shave the fenders.
Yokohama S.Drives
With tanabe springs, yes. 2" & 1.5" vs 1.8" & 1.3", plus different spring rates as well for the DFs and all of the other springs Tanabe sells.
http://www.tanabe-usa.com/springs/sp...tions.asp?id=1
![No No No](https://www.clublexus.com/forums/images/smilies/nono.gif)
Only by 50lbs
Only by 50lbs
