Updated Pics - 225mm springs on CS-T
I only replaced the front b/c I that was my main issue that the fronts didn't go low enough. Now that I'm slammed up front I'm thinking I might pick up a set for the rears to even it out a little more. I kept the same spring rate 9kg just got 25mm shorter spring.
Yeah he would know, since they were his
Ay-nako - Thanks....No prob you just wanna make sure you let the tint spray complete dry first. I'll let it sit for a couple of hours. I tried rushing it and spraying the clear only after 30 min maybe more and it will just ruin the tint. Then you are gonna have to use something like goof off and remove the tint and start over. So just make sure you let the tint is completely dry
