adjust headlight height, and changing bulbs??
i'm new here, and i'm sure its been discussed before, but i'm having a hard time using the search command to find anything.
everytime i type something under search, it gives me no results.
even mundane things like "headlight"
anyway,
can anyone help me adjust the height of the headlight beam and change the bulb on my 1993 gs 300.
any magic potions for cleaning the scratches, and discolorations on the headlight covers?? other than sanding it with sand paper??
anyway,
I've used these products before but not on headlights (BTW I found that they didnt work too well on LEXAN either).
The specific application is for LEXAN and I do not believe the GS headlights are built out of LEXAN so I dont think its gonna work.
i went to pep boys and bought a blue bottle of plexi glass cleaner and it got the yellow out of my headlight housing works good for me. just gotta make sure you shake before you use.
Hey Laser, if you have the manual for the GS it should say there how to adjust the headlights, IM not sure if my explanation will be much help since u can't see it for ur own eyes, But u need a Phillip screwdriver, And look for a small piece right behind the large headlight, Keep in mind ur gonna have to have the hood up for this, LoL but u insert the screwdriver in there and u can turn it whichever way u need it to go, but just keep an Eye on the bubble in the measuring thing to see if it's even or not, U have to have ur car on a flat level surface.... there is another slot for the screw driver right behind the DRL lights, that helps u adjust the highbeams as well.. sorry if this isn't good enough to help ya out
ShOwGS
ShOwGS
