GS400 Overheating question
I have a 2000 GS4 w/ 122k miles. After sitting at idle for several minutes this afternoon I noticed the temp guage almost pegged I didn't hear the fans running though. I began to drive and after less than 1/2 mile it cooled back down. I let it sit and idle again and could hear the fans kick on for 5-10 second intervals. After a few minutes the fans didn't come on and it began to heat up. After another minute or two the fans did come back on and run for a longer time and it cooled back down to normal. I believe this is going to be a temp sensor issue. But I'm not sure where it's located and how big of a headache it's going to be for a DYI. Any help would be appreciated.
Guest
Posts: n/a
1. Make sure all your caps/hoses are tight.
2. Your thermostat is probably bad.
You can DIY the thermostat, I think its like $50. I got a TRD one for about $75, its a better one that OEM.
Guest
Posts: n/a
Here is when it happened to me.
https://www.clublexus.com/forums/sho...&highlight=hot
Kharizma
Performance
11-20-06 04:44 PM
01, 2000, 400, fans, g400, gs, gs400, idling, lexus, overheat, overheated, overheating, sensor, temperature, thermostat
