Timing belt questions! advice needed
Old 12-11-08, 04:19 AM
  #31
JeffTsai
JeffTsai's Avatar
The valve cover gaskets are only $10 each, I would suggest you replace them to prevent any future oil leaks. I would not skip any of those things in the list. If they fail, then you will have to pull a bunch of stuff apart to replace those parts. Might as well do it all at once and be done with it and not have to deal with it for the next 100k miles.
Old 12-11-08, 12:44 PM
  #32
JoelGs
JoelGs's Avatar
Originally Posted by Billh2
After 18+ years in the automotive aftermarket, I can tell you when my Lexus needs something, I only use OEM parts. It's pretty much a given that an OEM timing belt will last at least 90K. Would you risk the possibility of bending half of the valves in your engine with a belt purchased off of EBay? If you did buy an EBay belt, installed it and it failed, who would you go back on? Not to say that I don't use EBay because I buy a lot of stuff there. I just wouldn't trust something so important in an expensive engine.
+1 on that...I would rather use OEM parts b/c it made for the car. Can not afford to waste time running around to get aftermarket crap cuz it doesn't fit well or other issue..IT a good thing that I've work for dealership, got a big saving...MY suggestion is stay AWAY from aftermarket...
spitfire7
Performance & Maintenance
01-27-15 09:19 AM
vs1979
GX - 1st Gen (2003-2009)
23
06-27-13 04:43 PM
rennwerkes
07-29-11 01:53 PM
SCLover777
02-02-09 07:57 PM
Quick Reply: Timing belt questions! advice needed
