Timing belt questions! advice needed
Hi, i am going to change my timing belt soon. i was wondering if there is any timing belt kit that's good qulity, but not as expensive as the the dealer price. 250 for a timing belt?!? that's too much. also can you give me a list of parts that i have to change? like:
timing belt
water pump anything else?!? never done it before. thanks in advance!
timing belt
i saw these two on ebay. what do u guys think?
http://cgi.ebay.com/ebaymotors/1998-...spagenameZWDVW
these have just the timing belt, Timing Belt Tensioner Bearing water pump.
http://cgi.ebay.com/ebaymotors/98-99...spagenameZWD1V
this one has more stuff 1 Timing Belt (Bando)
1 Water Pump (Aisin)
1 Serpentine Belt (Bando/Continental/Gates)
1 Tensioner Roller (Koyo)
1 Tensioner (Genuine Toyota)
do i need all the serpentine belt and all that stuff? what is it for anyways?
and should i even go with these. are they reliable? ty
Bando is actually a good brand as far belts are concerned, know of 3 turbo 2jz running the Aisin pump and Koyo is an OE manufacturer so I think all those parts are good. You do need a crank and cam seal too as well as maybe a valve cover gasket. And if you want to play it safe the ball joints and tie rods as well.
thanx guys. i will call up the dealers again 2m to make sure the price. if not i will go with this one: http://cgi.ebay.com/ebaymotors/98-99...spagenameZWD1V
it seems like these are actually the oem parts. and of course thanx for adding to my list. cam and crank seal and valve cover gasket.! thanx guys! anything else i am missing?!?
here is the list
cam plug (seal)
crank seal
valve cover gasket
here is the list
cam plug (seal)
crank seal
valve cover gasket
There can only be One
FYI on parts costs
https://www.clublexus.com/forums/sho...&highlight=90k
250 for the belt?
That doesn't sound right to me at all.
That Ebay price seems iffy to me.
199 for all that?
The OEM water pump alone is 175.
250 for the belt?
199 for all that?
here is the price i got from the dealer this morning
41.18 timing belt
82 tensioner
144 water pump
31.88 crank seal each
17.8 cam seal each
17.28 valve cover gasket.
total 350 plus tax
i have a questions. what is crank seal, where is it and what does it do?
41.18 timing belt
82 tensioner
144 water pump
17.8 cam seal each
total 350 plus tax
Here are some part numbers...
Timing belt 13568-49036
Tensioner 13540-46030
Idler 13505-46041
Drive belt 99366-D1930
Water pump 16100-49876-83
T/stat 90916-03093
T/stat gasket 16325-62010
two o-rings for the bypass pipe are:.... 96761-24022
o-ring for the bypass outlet is:............ 96761-24028
Idler 13505-46041
T/stat 90916-03093
After 18+ years in the automotive aftermarket, I can tell you when my Lexus needs something, I only use OEM parts. It's pretty much a given that an OEM timing belt will last at least 90K. Would you risk the possibility of bending half of the valves in your engine with a belt purchased off of EBay? If you did buy an EBay belt, installed it and it failed, who would you go back on? Not to say that I don't use EBay because I buy a lot of stuff there. I just wouldn't trust something so important in an expensive engine.
