mechanical noise coming from dashboard
first post on cl...
i just picked up a 98 gs300 and i noticed a mechanical sounding noise coming from behind the steering wheel. it sounds almost as if the cd changer is changing discs but it is almost constant. the noise is very low but i am wondering if anyone else has had problems with noises coming from this area. i dont think that its coming from rubbing it sounds like a motor or pump of some sort.thanks!
i did search the forum but i could not find any threads describing the same noise that i had....i opened the hood up but the sound is only audible from inside the car... it is coming from somewhere behind or under the steering wheel...any suggestions?
That's normal for the GS!
The noise your hearing is the brake fluid actuator engaging! Thgat's normal for the GS to do this upon starting.
THANKS so much wringo for putting my mind at ease....is it normal for the actuator to continue to make noise even while the car is moving..it pretty much happens everytime the car is not in motion.
basically when i turn on the car i can hear it...it sounds like a motor or pump clicking but the sound is sporadic i can often hear it while driving..it almost always occurs when idleing tho...
Does it do it with the ac on only? could this possibly be the AC servo's (sp)
I have seen on here and experienced this same noise coming from behind the dash - When i turn the ac off the noise goes away .
the noise is constant no matter how long i have been driving. it is definately something mechanical and not a rattle...im just wondering if theres anything i can do before taking it to the dealership to get f'd in the a
If so, there's your culprit. There are some threads here on this topic.
