difference between gs300 98-00 and 01-05
as the title suggests
this is because some sites have parts for 98-00 and have a different listing for 01-05
this is mainly for external parts
but in any case... is there a difference?
Guest
Posts: n/a
SEARCH please
You can look at this thread
https://www.clublexus.com/forums/sho...d.php?t=266534
and see changes, they also went to the 300. The BIGGEST change was the addititon of e-shift from 01-05
Tails/grill/wheels/headlight tint are the main exterior changes (if not the only exterior changes).
Aftermarket parts fit all 98-05 GS 300s
GS series II: Facelift changes - 2001 model
November 2000 saw the launch of the 2001 GS. Whilst still a series II there were a number of changes throughout the vehicle.
Model line-up
GS300 sport shift
GS430
Exterior
New rear light cluster design
New front light design
New front grill
New exhaust tip design
Interior
Chrome trim around gear shifter
New dashboard dial trim
New steering wheel design with larger chrome L badge
Colour of centre air vent and instrument trim revised
Front ashtray is now in wood rather than grey plastic
Different stereo, although seems the same quality as the older one
Sat Nav option upgraded to DVD based system with widescreen LCD display
Increased sound insulation
Engine
Improvements to economy and reduced emissions
Iridium spark plugs
Engine cover now fitted
Transmission
GS300 now comes with E-SHIFT, push button steering wheel mounted gear selection
Safety
Brake assist
Electronic Brake force Distribution
Curtain airbags
Double locking doors
Seat belt pre-tensioners
ISO-FIX child seat fixings in the rear seat
Brakes
Larger brake master cylinder
Suspension
Improved shock absorbers
Uprated anti-roll bar
Revised suspension bushings
Servicing
Service interval is increased to 10,000 miles from 9,000 miles. Cam timing belt change interval increased to 100,000 miles from 63,000 miles
blkhawaii
06-26-06 09:38 PM
