gs430 engine swap??
gs430 engine swap??
saw a gs430 for sale with a bad motor, and was wondering if you can swap a 4.7 in there. just looking for a straight bolt-in engine swap. not looking to do custom mounts and stuff like that. thanks
For starters I know that the oil filter is in a different location. The oil pans are different.
Lextreme is the right place to go. he put a 4.7 L block into an SCxxx. He reused the 1uz(4.0 / 4.3) heads onto the 2uz (4.7). I think the core block is the same but you will probably need to change everything short of the block.
http://www.lextreme.com/1uzfe_info.html
or
www.lextreme.com/1uzfe.html
BTW.. where is the GS430?
BP
or
BP
Why would you spend the money to get just .4 Liters? Just do the GS430 swap and call it a day. I think the 4.7 is a great upgrade for the 4.0 but not the 4.3.
da808n
Performance & Maintenance
02-03-05 08:20 PM
