Hi-beams on headlights no working...
Afternoon to all..I have not Hi-beams on my headlights on a 2000 gs300..I checked all of the bulbs and replaced them and can hear the clicking noise when i try to turn the high beams on but no luck so far....Is there a hi-lo switch that goes bad and has anyone changed it before of had the same problem..
Are the connections on tight? Check your fuses. There are 2 locations. On a 430 they are by the battery and in front of the drivers side strut tower. Don't know if they are the same with a 300? There is also a relay on the drivers fender and a resister behind the drivers strut tower.
Check the wiring for the high beam circuits. There may be a wire that's disconnected. Check your DRL box to see if it's plugged in correctly. Also, you may want to check your battery. Make sure the terminals are correctly placed, and TIGHTLY bolted.
nordoyan
08-07-14 05:58 AM
