How to programe the remote on 02 GS430
See this link.. I think this is what you want.
https://www.clublexus.com/forums/sho...ramming+remote
This should help.. my wife made fun and asked if she need to run around the car three times to get it to work.. ha ha ...
BP
BP
I try this method two times. at the begining, everything like what he descripe. except the last step when i press the lock button. The door will not unlock. I guess this method will not fit my car.
These are the correct instructions:
Remote Programming
1. Open driver door, keep it open and in the unlocked position (all other doors should be closed)
2. Put original key in ignition and pull out
3. Lock and Unlock the doors 5 times (complete each lock/unlock cycle within 1 second and
entire process in 40 seconds or less)
4. Close the door and open the door
5. Lock and Unlock the doors another 5 times (complete each lock/unlock cycle within 1 second and
6. Put the key in the ignition, turn it to "on" and then off (with 1 second) and remove from the ignition.
7. Press and hold transmitter LOCK and UNLOCK buttons simultaneously for at least 1.5 seconds,
and then within 3 seconds; press any transmitter button for at least one second.
8. If within 3 seconds, door locks cycle one time, new transmitter code was accepted. If door locks
cycle 2 times, new transmitter code was not accepted. If code was not accepted retry step 8 again.
Because those are the wrong instructions (similar, but different towards the end).
Remote Programming
Remote Programming
see here for proper instructions: https://www.clublexus.com/forums/sho...83&postcount=8
