Photo Shoot of my GS300 - 56k oh noes!
#50
neo~you still got finger gap and the fronts are all the way down? no way! i had about 3/4" of thread left on my fronts and i was about flush, zero gap. gotcha on the rears though...i'm planning to slam it completely down in few months, trying to be like you HEHEHEHEHEHEHe ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
did you ever adjust your damper settings? i'm afraid to adjust mine, if i change to softer, i'm afraid i'll rub something inside
Actually, I have yet to mess with the damper settings. It rides perfect and I don't want to mess it up. You know the old saying, if it ain't broke, don't fix it.
#51
#53
I thought the same thing when I got them and put them on. I wanted something fully polished or like a brushed aluminum, but I got these at a great price, so I really can't complain I guess. I'm thinking if I add a little to the car (like kit, puddle lights, curtins...) that my sway the thinking of the 'DUB' style. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
About the RCA's, you might run into problems if you use them to get lower. Depending on your tire size and offset you might get bad rubbing and scraping because you lose some camber. And your control arms will bottom out for sure. I have the same problem so I'm researching some air options.
#59
Yeah those wheels went at a great price. It would be hard to say no. I trust your taste in VIP style and I can tell you can pull it off nicely. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
About the RCA's, you might run into problems if you use them to get lower. Depending on your tire size and offset you might get bad rubbing and scraping because you lose some camber. And your control arms will bottom out for sure. I have the same problem so I'm researching some air options.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I was never handed anything in my life growing up. I had to work hard for what I wanted. When I get any positive comment about my car, it makes me push that much harder to get this car where I ultimately want it.
Thanks a lot guys. I really do appreceate all the comments
