need help with door lock
i got question about my driver door...it seem like when i press the unlock key in the remote ..only 3 door unlock except for the driver side...but when i get into the car,try to switch the lock manually to lock position then press unlock on the driver side it unlock all the door....i don'tt get it..help me..thank
check that there isn't a c-best setting programmed into your car which is preventing your drivers door to unlock. the dealership can hook the computer up to determine if this is the problem or not. simple fix if it is.
mine did that once. i bought a door look actuator off of ebay for $199. i haven't installed it yet because it only happened when it was really cold outside. buy one just in case the problem becomes more persistent, then you'll have it ready to install whenever you need it.
It is more than likely your door lock actuator. See the following.
https://www.clublexus.com/forums/sho...d.php?t=288923
look for door lock diy
BP
BP
aespinalIS
02-26-15 10:10 AM
a#'z
03-02-09 09:25 PM
