What in the world just happened??...
On my way home from work this evening, while stopped at a 4-way stop, my car just bogged down… felt like the engine itself shut off but the radio stayed on. Simultaneously, every indicator light on the dash lit up and the needles dropped to 0. In a panic, I turned the car off and restarted, then causally drove the rest of my way home, luckily only about another half mile. I have never experienced anything like this before, has anyone else? Also, can anybody off me an explanation?
I checked the battery connections when I got home, and they all look good.
Thanks you in advance
If it happened at idle not while your foot was giving it the gas I would check the throtlebody the PCV valve returns right back into the air intake near the butterfly and sometimes oil crude will build up and cause idle air issues.
BP
BP
thanks guys,
i was detailing under the hood yesterday and discovered a very loose connection with the neg battery terminal. problem solved. appreciate all the input
19x11.5 -51
Mine did this on the free way going 75 ...
felt like i had something stuck in the tail pipe .. wouldn't go when i gave it gas ...ended up slowing down .. pulled off car wouldn't start ... for 30 mins .. then when a tow truck got there ... same issue .. then the next day
I tried to start the car . worked fine .. ever since
I checked alot of things and yet to find out what happened ...
Quote:
Originally Posted by Ay-nako
+1 this just happened to me!
Quote:
Originally Posted by cliffud
ditto. i've had the same thing happened and i had bad battery connections.
QUOTE=augdogg;3347189]+3 Battery connection....[/QUOTE]
+4 Happened to me last month on my TL.
