Dash Lights?
Dash Lights?
how do u take out the bulbs in the dash ?
not the tach or speedo lights..but the other lights ...like the door open / airbag/ etc. .. how do i pull out a bulb?
thanks . . .
thanks . . .
I searched and found this for ya
https://www.clublexus.com/forums/sho...d.php?t=339979
https://www.clublexus.com/forums/sho...d.php?t=339589
As the guy that did it, it is. But you are not going that far. Follow steps 1 through 4, and then skip to step 8 to see the bulb or how it should look like on the back side of your cluster.
As far as the passenger bulb, simply use a plastic screwdriver and slide it between the leather dash assembly and plastic, 1st start by the clock then work your way over to the hazard buttons, work it loose, to pry or you will ruin your dash. Twist that little bulb thing out.
smesseng
Performance & Maintenance
09-07-13 09:26 AM
