help! with fog lights
i bought a used driverside oem fog and keep the pass side the same on the car.. put in superwhite bulbs and pass side comes out pure white and driverside comes out PURE YELLOW! any idea why.. doesnt seem to be any yellow tint inside .. is it true gs 300 fog are white and gs400 are yelllow? what i was told .. thanks guys
Yea, there is a yellow capsule. Find someone to trade with, although there aren't too many people with single clears. Another option is to break the yellow capsule, but then that would be a waste of a good fog.
Originally, you can get yellow foglights with cars that are equiped with HID.
ok here goes ..had 2 fogs that gave out white light unless i put in yellow bulbs .. got into an accident and the driver side fog got ruined .. bought a used oem fog for the drivers side and its gives out yellow light with the same white bulb in .. why is one fog yellow and 1 white when they both have white bulbs in ? did the previous owner of the car remove the yellow cap to make my prev fog white?
if you do not want the yellow light.. (backup) there is a yellow capsule inside the fog cluster. it surrounds the bulb, therefore when the bulb emits light, the yellow glass surrounding where the bulb fits in changes the color. If you do not want this the simplest way of getting the yellow away is the way i did it..... take a LONG flathead screwdriver and repetitively bash into the cluster until all the yellow shatters. When it shatters then shake all the glass out. REMEMBER it is glass, not some kind of plastic so PLEASE BE CAREFUL (I can and will not be responsible if you hurt yourself, your foglight or anything!!) please please be careful. But i hope this helps. if you have any more questions just post and hopefully i can help. BTW i did this on my '00 GS400 with stock yellow fogs
-Joe
-Joe
D-MAN63
06-17-02 04:42 PM
