Air horn wiring help
Anyone install a set of Hella air horns? If so how did you wire the relay?!? I am stumped on where it says wire to the horn, the diagram says wire to 2 wires at the horn but the GS horn only has one wire in the loom/harness clip. What did you guys wire to?
***EDIT** I figured it out, please lock or delete.
Yeah, I should have updated with the configuration that worked. The prong 85 on the relay is what had me confused since the instructions said that it went to a positive from the horn wire when in fact it needs to be grounded instead on the GS.
So at the relay -
Prong 30 goes straight to a 12v source
Prong 87 goes to the positive on the air horn compressor
Prong 86 wires into single factory horn wire
Prong 85 gets grounded
Works like a charm!
So at the relay -
Works like a charm!
