01 GS430 quit running...
Old 03-19-08 | 10:13 AM
nate579's Avatar
nate579
Default 01 GS430 quit running...
My first failure in my GS after 4 years. Taking my little girl to visit grand parents. At the red light of a busy intersection. The car shuts off and failed to start. I mean nothing dash board lights are on but that's it. Well lucky the police showed up and AAA tow truck after 15 minutes. Having it towed to a lexus dealership. The car has 82,500 miles on it hasn't been driven in a few weeks. Battery seems good. Just no clicking or anything when you turn the key. What can it be??? NO CEL
Old 03-19-08 | 10:21 AM
Saiji's Avatar
Saiji
Hmmm no clicking at all? Did they check your starter?
Old 03-19-08 | 11:33 AM
KevinGS's Avatar
KevinGS
Hmmmmm... that's strange, Nate. Keep us posted on what the dealer says. Hope you had it towed to Lindsay in Alexandria so Brad could take care of you.
Old 03-19-08 | 12:05 PM
UncleRay's Avatar
UncleRay
Wow... this is strange... I would definitely have the dealership check this out. If there's no clicking, then your battery is good. I think it could either be your starter, or a fuse.
Have it checked out =] Good thing you're safe!
Old 03-19-08 | 02:32 PM
nate579's Avatar
nate579
You know I did, he has his guys looking over it. But they so far are stumped. Hopefully it is something simple.
I am shooting for a fuse, if so then I think I know what happened. I removed a after market amp yesterday and disconnected the power wire from the battery, so I thought. Wondering if it grounded out and a caused a fuse to blow. It's a scary feeling stuck on a busy highway with a 19 month old toddler. Lucky Park Police came by they know a friend of mine who I went to the Academy with. So the baby got to ride home in the cruiser. Too bad she won't remember it.
Oh forgot to mentioned that the tow truck tore off my TTE Lip. The guy was being very careful, put blocks up and everything but the cable took it right off. He was very apologetic and everything. I told don't worry, my priority is getting the baby home, just throw it in the car and I will deal with it later.
Old 03-19-08 | 02:58 PM
minla007's Avatar
minla007
i had that happen to me once too...car was running fine, then all of a sudden it just shut off...no lights, nothing....but in my case, it started back up
i tightened up my battery connections and it has not happened since....since you were messing w/ the battery that day, maybe check to see if the battery connections are real tight?
i'd like to hear what lindsay has to say bout this too...very weird...
Old 03-19-08 | 03:52 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Sounds like a loose, or rusted negative battery terminal.
Old 03-19-08 | 03:59 PM
L3XOTIC's Avatar
L3XOTIC
hope all goes well as its very uncommon for the GS's to break down like this.
Old 03-19-08 | 08:15 PM
tone4's Avatar
tone4
Same happed with my 1st gen, was alternator.
Old 03-19-08 | 09:44 PM
pitmanr200's Avatar
pitmanr200
i always thought that once car was running you could unhook battery and car would still run. That is how I used to test if it was alternator or battery. Is something different on lexus. I would think alternator if it was me. but i am by know means a mechanic.
Old 03-19-08 | 10:06 PM
DallasLex's Avatar
DallasLex
I hope it's nothing major. Best of luck to you.
Old 03-20-08 | 11:59 AM
nate579's Avatar
nate579
UPDATE: AM2 fuse blew. Phew, I thought it was something major. But she is all repaired and ready to go. Hopefully it is a one time thing. I am thinking that removing the aftermarket amp may have been the cause. Make sure I tape the wires up or remove them. THANKS BRAD. You the Man!!!!
Old 03-20-08 | 02:34 PM
mex lex's Avatar
mex lex
Glad to hear everything is ok and it wasn't nothing serious.
Old 03-21-08 | 02:39 PM
nate579's Avatar
nate579
The problem was the removal of the aftermarket Amp, even though the main power wire was diconnected from the battery. I failed to tape the ends of the remote on wire and the ground leads in the trunk. So u know what happened when those 2 touched. I brund electrical tape to tape the down and my dumb azz grounded them out right out the dealership with the car running. My wife laughed so hard. I think I even seen a giggle from the baby. "Dad's an idiot". Replaced fuse, taped everything up start the car when on my way. Again want to thank BRAD at Lindsey Lexus. Great Guy Great Service.
Hsafe67
09-02-18 11:20 AM
Patsum
03-03-12 01:46 PM
Och
05-04-07 07:49 AM
slugmike
Performance & Maintenance
12-18-05 11:00 AM
roller400
11-10-04 02:01 PM
Quick Reply: 01 GS430 quit running...
