Different Motor Oil
Old 03-21-08, 10:21 AM
handzilla
handzilla's Avatar
Default Different Motor Oil
What motor oils other than Mobil 5W-30 have you tried in your 2GS? I'd like to know b/c I'm contemplating switching to a thicker oil since I'm at 130k.
Old 03-21-08, 10:28 AM
Chris2
Chris2's Avatar
I only use what the dealer gives me but I know there is a Royal Purple brand that is way thicker and supposedly better for higher mileage cars. I have yet to try it. Maybe once the free oil changes run out I'll give it a shot.
Old 03-21-08, 10:34 AM
GSteg
GSteg's Avatar
No need for thicker oil. Just run what you've been running. If you're not leaking oil or burning oil, then just leave it the way it is.
I've ran the following:
5w-30
5w-20
0w-30
0w-20
and then mix of in between. No problems whatsoever. I decide on oil based on my driving condition.
Old 03-21-08, 10:45 AM
RI-Lex
RI-Lex's Avatar
Mobil 5000 here 5w-30 and still change it every 3k miles
Old 03-21-08, 10:50 AM
BCP43002
BCP43002's Avatar
I use Castrol GTX in all my cars.
Old 03-21-08, 11:01 AM
LEXUS_KID
LEXUS_KID's Avatar
Mobil 1 only nothing better
handzilla
handzilla's Avatar
I've been using the 5w30 and am losing oil due to blow-by as noted by the stealership. They said it's due to normal engine wear. I've done some searching and have read that using a thicker oil such as 10w30 or 10w40 might help slow the consumption. Can anyone atest to this?
Old 03-21-08, 12:36 PM
blacksc400
Car Chat Moderator
blacksc400's Avatar
I use 5-30 in winter and 1-40 in summer.
It is always 100 degrees here in summer!
Old 03-21-08, 12:54 PM
overboost
overboost's Avatar
that depends on what exactly is wrong, whether or not your actually burning any oil due to rings or anything else. How many miles are on your car?
Old 03-21-08, 01:23 PM
handzilla
handzilla's Avatar
130k. Not sure what else the problem could be. I haven't seen any leaks. Dealership sais it's blow by.
Old 03-21-08, 08:51 PM
dl5
dl5's Avatar
i'm using mobil 1 5-30w 15kmile oil, i change it every 6 months though, which is about 4k miles. i'm going to try german castrol synthetic soon, 0-30w. it says zero, but everyone has said despite the numbers, its more like a 5-40w. can anyone confirm? i'm worried about having problems blowby.
Old 03-22-08, 01:28 AM
swat1727
swat1727's Avatar
oil is oil. i dont drive my gs hard anyways. just change it every 3k. (btw i live in sf, part in garage, no tem change through out the year.)
Old 03-22-08, 10:17 AM
UncleRay
UncleRay's Avatar
Castrol GTX syntec 5-30 all the time, and a Mobile 1 premium oil filter
Old 03-22-08, 11:28 PM
tommyjaix
tommyjaix's Avatar
a steal for $24.99 from auto-zone. woot! but I have to go out and buy an extra quart of mobil 1 5w-30 15k oil to meet the 5.7Qt requirement for the 2jz
Old 03-23-08, 12:30 PM
qgoat
qgoat's Avatar
Thats what my dealer put in my car when I had my 150k service. Before that I was using valvoline durablend. No problems so far. I guess I will stick with Castrol since dealr recomends it.
Quick Reply: Different Motor Oil
