Got back late so the lights were on but you can tell the difference instantly. AFTER:
(Condensation is my next project) Maybe a hair dryer or vaccum tube will do the trick without removing the housings......
for condensation in the headlight try removing the "U" shaped rubber plugs in the rear of the headlight...I removed mine and it solved my condensation problem.
Rubbing compound, plastic compound, etc..most work fine. I use paint polish and compound, and it works. The compound acts as a mild sandpaper that will get rid of the surface contaminants. Step it down to a finer polish (like plastic polish) to increase surface shine.
^^ I have had mine on for about 6 months now and they went through the very harsh NE weather and still are as good as the day I buffed them , you should have seen how they were before I reworked them.
